Discussion topic: Slow speed playstation
This message was authored by: Led80
When running a test on my son’s PlayStation 5 it states it is receiving 1-10 mbps.  We have the ultra broadband package so unsure why this is. Can someone help?
Re: Slow speed playstation
@Led80
Is it connected via WiFi or ethernet?
I am NOT a Sky Employee
Avatar for Led80
Wifi.  Thanks.
@Led80
Thats probably why then. WiFi speeds can fluctuate massively depending on conditions & distance. Additionally the WiFi antennas in the PS5 are not that good. I would recommend you use ethernet for any sort of gaming device, you may want to look at powerline adapters if direct ethernet isnt an option.
Avatar for Led80
Thank you.  Just thought it was odd as I'm getting over 100mbps on my phone.
