Discussion topic: Sky Broadband WIFI Issues
This message was authored by: Andrew+Goddard
Ever since I have had Fibre installed and the modem moved, my WIFI has slowly been dropping off, I have a booster that I thought was in a responable position but its a struggle to get anything connected to our wifi that isnt within a couple of meters of the main hub!!
Try as I might I cannot find a telephone number to contact and its got to the point where I feel like I am just living with it and that isnt right!!!
Re: Sky Broadband WIFI Issues
@Andrew+Goddard
The number is either 150 from your landline or the 03 number at the bottom of https://sky.com/help under the 'Need more help?' banner.
I am NOT a Sky Employee
Avatar for Andrew+Goddard
Thanks James, Ive tried that and it dosnt appear to want to play ball and give me the number.
The 150 number, do you mean from a Sky Mobile?
@Andrew+Goddard
Sky Landline only I believe
