Discussion topic: Slow ethernet speeds
This message was authored by: Jay_barnie34
Message posted on 10 Sep 2025 07:13 PM
I just got wifi fixed them when I come on my ethernet speeds r now like 15mb and can't run anything and no fixes work on my computer
Find out more
Message posted on 11 Sep 2025 07:49 AM
Re: Slow ethernet speeds
@Jay_barnie34 assuming it is a direct cable from the hub to the device there should be no speed loss. You can check the speed of the connection from the exchange to your hub by looking in the service checker in the My Sky app as Sky measures thst daily.
If the cable is not direct but perhaps linked to a WiFi extender or you are using powerline adapters then those are the likely cause.
