Discussion topic: Slow download speed
This message was authored by: Mateface11
Slow download speed
Our download speed keeps dropping to almost 0 however the app says there are no faults. Is there anything I can try to be able to stream Netflix etc
Re: Slow download speed
@Mateface11 What is the normal speed that you have for your system and which sky hub do you have? Is the speed issue just a new occurence or something else has happened to cause like i did an upgrade before and now it's poor. Link to hubs below.
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
