Discussion topic: Slow Wi-Fi while using laptop
This message was authored by: Ajay5
Slow processing to my laptop. The laptop is new so that should not be a problem .using wifi, any solutions?
Re: Slow Wi-Fi while using laptop
@Ajay5 uf tge WiFi signal is poor either move closer tomthe hub or consider getting better wifi kit. Sky will sell you an add on which can give you up,to 3 WiFi extenders see https://www.sky.com/help/articles/sky-wifi-max or you could buy your own equipment and use thst instead.
