Discussion topic: Slow Speeds
Message posted on 13 Jun 2025 01:44 AM
Slow Speeds
So I've been promised speeds of minimum 37 mbps when right now I'm on maximum 5, I've had this WiFi for 2 weeks now so there shouldn't be no excuses anymore
Message posted on 13 Jun 2025 05:31 AM
Re: Slow Speeds
@CooPz24 If you run the service checker, look at the broadband you will be able to see what sky have for the period on there checks off once per day!
This should determine if there's an identified fault affecting multiple households.
Message posted on 13 Jun 2025 08:22 AM
Re: Slow Speeds
I have tried everything and it's still the same it's really not good enough
Message posted on 13 Jun 2025 08:39 AM - last edited: 13 Jun 2025 08:41 AM
Re: Slow Speeds
@CooPz24 What does the last 30 day's look like! or do you not know how to look at that!
Message posted on 13 Jun 2025 08:45 AM
Re: Slow Speeds
Well my max speed is 6mbps now I know for a fact that isn't good enough at all especially when I've been promised way higher than that, I can't even do anything on it, it's saying on the app that there's a problem with the connection of the hub but I went to fix it and do every step it said and it's still not working, if it's gunna be like this though I wanna look to move elsewhere and have a refund
Message posted on 13 Jun 2025 08:49 AM
Re: Slow Speeds
@CooPz24 When you run the service checker, then if you click on the broadband you will see every day result for the 14 day's period that your hub has been connected to the system for the daily check that sky makes!
Message posted on 13 Jun 2025 08:50 AM
Re: Slow Speeds
Yes I've done that and it's all slow speeds
Message posted on 13 Jun 2025 08:54 AM
Re: Slow Speeds
@CooPz24 If that is correct, then you need to call sky and have them run a diagnostic against your line and the hub, without knowing what you have it is difficult but pointing towards a poor line connection.
