Discussion topic: Saddleworth broadband down
This message was authored by: Franke
Have anyone else lost briadband in Diggle?
Re: Saddleworth broadband down
@Franke
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby. Note: the service checker sends routine tests to the hub and won’t necessarily register any issue until the hub fails to respond.
