10
This discussion topic has been answered Discussion topic: Slow Download Speed - Do I Leave?
This message was authored by: ChrisEJ1993
Hi everyone, I'm looking for some advice.
I am on Sky Broabnand 35, which sugests speeds of between 32MB and 37MB at my address and guarantees at least 30MB. But for quite some time I've been getting in the region of 20MB (today 21.8MB).
I went through Sky's online troubleshooter which just tells me to unplug everything and plug it back in again, which obviously I have done, and then claims to have fixed my broadband! Except it hasn't, because the speed is exactly the same and if you restart the troubleshooter it still says there "appears to be a problem".
By email, Sky have confirmed that I can change my package or leave without a penalty because they aren't giving me my guaranteed speed. But is there any point leaving? Its all the same wires, isn't it? So, would another broadband provider not have the same issue? For the record, I am not in a Virgin / Zzoomm / BeFiber etc area.
Thanks in advance for your advice.
Re: Slow Download Speed - Do I Leave?
@ChrisEJ1993 given Sky have given you the option to leave it looks likeky Openreach have refused to do work on your long line to enable it to offer the speed range the checker says itvshould support and the stats indicate. At some point they will change the database but if you order from another ISP now they will base their speed guarantee on the database but you are going to go through the same rigmarole as you have with Sky as in practice the line will deliver the speed you get now.
If mobile signal is poor the only other solution I can think of is Starlink which uses satellites but is quite expensive. This issue will only be really solved when full fibre is run to your property that could be years away.
@ChrisEJ1993
Could you post your hub stats
And enter you full address below and post the table after removing you address from the image
@ChrisEJ1993 switching to any other isp using the same Openreach line will deliver  the same speed as it is the length and condition of the line thst sets the speed. Increasingly Openreach are unwilling to upgrade copper lines as they switch to full fibre which doesnt help customers like yourself stuck at the end of a dodgy copper line who get the message you have had.
One possible solution is mobile broadband if you have a decent signal as thst need not be prohibitively expensive.
Avatar for ChrisEJ1993
@cookiemonsteruk:
Router Statistics:
System Up Time: 2802:00:34
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 361628250 586122289 0 22708 24206 1098:02:00 LAN Down 0 0 0 0 0 00:00:00 WLAN (2.4 GHz) Up 53090076 27798698 0 584 38 2801:58:43 WLAN (5 GHz) Up 628839103 395347848 0 0 0 2801:58:41
Broadband Link Downstream Upstream Connection Speed 24259 kbps 6263 kbps Line Attenuation D1(17.3 dB) , D2(45.0 dB) , D3(69.0 dB) U0(5.8 dB) , U1(40.9 dB) , U2(55.4 dB) Noise Margin 12.1 dB 5.8 dB
BT Wholesale:
[Redacted] on Exchange BURY is served by Cabinet 79
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Handback
Threshold(Mbps) WBC FTTC Availability WBC SOGEA Availability High Low High Low       VDSL Range A (Clean) ChrisEJ1993_0-1724609054230.gif
49.9 35 8.9 6.5 32.4 Unavailable Available VDSL Range B (Impacted) ChrisEJ1993_1-1724609054230.gif
48.8 32.4 8.8 6 27.4 Unavailable Available G.fast Range A (Clean) ChrisEJ1993_2-1724609054230.gif
-- -- -- -- -- Unavailable -- G.fast Range B (Impacted) ChrisEJ1993_3-1724609054230.gif
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install Process FTTP on Demand 1000 220 -- Available --
Other Offerings Availability Date VDSL Multicast Available
Exchange Product Restrictions Status FTTP Priority Exchange Y WLR Withdrawal Y SOADSL Restriction N
@Anonymous Thanks for your message. Unfortunately, mobile broadband isn't an option for me here becuase the mobile signal is too weak.
@cookiemonsteruk: Please find both attached as requested. Firstly, my router statistics:
And secondly, my Openreach information:
@Chrisee: Thanks for your suggestion. Unfortunately, mobile broadband isn't an option for me as the mobile signal here is too weak.
@ChrisEJ1993  The openreach information can you post the text below where you stopped with the last screenshot please.
@Highlinder @cookiemonsteruk Please find the missing information from the Openreach screenshot below:
Thanks.
Thanks @Chrisee that's really interesting. What I find frustrating is that the 4 houses in my road all have 900MB options for broadband but my block of 7 flats, literally 30 meters away, doesn't. Is there any way I can encourage Openreach to consider upgrading the block do you think?
@ChrisEJ1993 First check this site to see what if any plans are in place https://www.openreach.com/fibre-checker. It is also worth talking to whoever manages the block as they have to agree to allow Openreach to fit the new kit and what if anything  has happened so far. On small blocks Openreach will run a connection to each flat but in a block of 7 flats I suspect they would want to have a multiuser supply to the building then running internal fibre to each flat. That requires agreement from the freeholder if they are not ageeing to the work pressure from the residents can change minds. More here https://www.openreach.com/fibre-broadband/fibre-for-home/ultrafast-full-fibre-broadband-to-your-apar...
@ChrisEJ1993  Seems like there is a capcity issue in your area and as @Chrisee  points out that you are able to leave withour penalty from Sky they are not willing to fix this issue. Moving to another provider might then get the work done or come to the same as what Sky has done.
Seems a rock and a hard place just now.
