3
This discussion topic has been answered Discussion topic: Sky won’t work
This message was authored by: Jatsbains
Sky won’t work
I'm getting tired if tho problem all the time nine if the tvs are working
Re: Sky won’t work
@Jatsbains @Tim185
If you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
Avatar for Jatsbains
Level 0 icon
Re: Sky won’t work
The tv and internet are not working
This message was authored by: Tim185
Re: Sky won’t work
Same here , has happenned for several evenings at around 22.30.
Re: Sky won’t work
@Jatsbains @Tim185
