1
This discussion topic has been answered Discussion topic: Internet has cut out
This message was authored by: Anj01
Internet has cut just out.
is there a problem at the exchange?
Re: Internet has cut out
@Anj01
If you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
@Anj01
