Discussion topic: Sky wifi max not working
This message was authored by: Ellib92
I recently upgraded to the sky wifi max hub as my previous Internet and router had issues. Now it seems to be happening again. At around 2am Ive lost wifi on all my devices and could not find my router in WiFi list its disappeared. I have tried to restart my router but it doesn't help. It's showing that there's no issues when it's running checks
Anyone else had to deal with this?
Re: Sky wifi max not working
@Ellib92
At 2am in the morning it could be overnight maintenance taking place.
If it still down later then the first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Avatar for Ellib92
Still no internet, and the hubs just been on a continuous flashing green light all night. Run a check again and it's saying there's an issue with the broadband. Followed all the steps again that it's gave and it's still no good.
Had so many issues with sky Internet over the last month. I wouldn't mind but I work from home, and need the Internet.
@Ellib92
@Ellib92
Appreciate that but Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won't receive additional or quicker support.
Avatar for Ellib92
Is there any way of resetting the wifi max hub?
This message was authored by: toshiba
Hello I still do not have any internet connection as I was promised it would be fixed on the outside of the house I still have no phone line or telephone would someone come on Saturday morning if it's possible to help out thank you for your time yours Peter persons
Would you like to meet to be in on Saturday morning because that's the best time for me can you let me know as soon as possible thank you for your time p persons
@toshiba
This is a customer led discussion forum where Sky customers are here to try to help other customers. You aren’t speaking to Sky Customer Services here.
@Ellib92
Your duplicate thread of this afternoon asking the same has been removed to prevent duplication of replies.
@Ellib92
If you mean the white hub (which I don't have) a previous post from @Chrisee has suggested this…
removing the power will cause the hub to reboot but to do a factory reset on the white hub 6 you press and hold in the WPS button on the side until the led flashes and then release it which takes at least 10 seconds.
