This discussion topic has been answered Discussion topic: WiFi not working
Message posted on 18 Sep 2025 03:50 PM
Getting my WiFi to work
Message posted on 18 Sep 2025 03:55 PM
@Wifi25
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
@Wifi25
