Discussion topic: Sky wifi max location avaliabilty
Message posted on 11 Jun 2024 12:58 PM
Where is sky wifi max available because i can select it online at my address as a new customer but not if upgrading to sky glass and then being told it is not actually available when speaking with them on the phone
Anyone else come across this?
Message posted on 11 Jun 2024 01:03 PM
Re: Sky wifi max location avaliabilty
Sky Max isnt limited by location, the only limiting factor is if you have Sky Q with more than one node
Message posted on 11 Jun 2024 01:07 PM
According to sky it is. First i was told it was because I have Sky Q which is fine, and when i was on the phone to them to change to sky glass they said it is not available because of where i am, even though as a "new" customer it is
Message posted on 11 Jun 2024 01:18 PM
It'll likely be because your on Sky Q though. I suspect if you moved to Sky Glass then after that was completed, requested Sky Max they would let you order it
Message posted on 11 Jun 2024 01:22 PM
That is what im thinking, but they keep telling me it based on location. Got that from 3 different advisors and only 1 said if i had/get sky glass or stream i would be able to get it
Message posted on 11 Jun 2024 01:24 PM
If Sky has a record of there being Q television with more than one Q Mini box (or a Q booster) at the address then the option to sell Max is unavailable.
Message posted on 11 Jun 2024 01:48 PM
I get that and understand, why cant they just say that
And just had someone from sky ring me still saying it is not availiable in my locality
Message posted on 11 Jun 2024 02:04 PM - last edited: 11 Jun 2024 02:08 PM
My guess is it's the result of inadequate staff awareness and a very unhelpful database message generated by their sales system.
'Not available at the location' is technically correct, but fairly useless as information...
Message posted on 11 Jun 2024 02:15 PM
Message posted on 11 Jun 2024 02:18 PM - last edited: 11 Jun 2024 02:18 PM
My usual thought is that Glass may be worth it if you really like the design aesthetic of the set, value the speaker array or need the credit terms: otherwise look at Sky Stream with the television set of your choice. Glass is approaching three years old and still alarmingly expensive, QLED rather than OLED and not particularly versatile.
Message posted on 11 Jun 2024 02:48 PM
I like the tv, we are looking to replace the tv downstairs as its old so was thinking along that route, and to be able to get sky wifi max to mange kids devices
Message posted on 11 Jun 2024 02:49 PM
Fair enough: I just thought I'd mention there are undoubtedly 'better' sets available for the same or even lower cost for use with a Stream puck.
Message posted on 11 Jun 2024 03:10 PM
@TimmyBGood oh yeah there is especially for the price. I did also look at sky stream but seemed to get a better deal on tv and broadband packages with sky glass
