Discussion topic: Sky suddenly not working
Message posted on 21 Jun 2025 04:37 PM
Message posted on 21 Jun 2025 04:40 PM
Re: Sky suddenly not working
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
