4
This discussion topic has been answered Discussion topic: Openreach installation
This message was authored by: Lb2456778
I already have the openreach box installed so do not need another one and I have had a message to say they are coming to install this week as we have upgraded to full fibre. I don't want to cancel it just incase they still need to come. I am assuming it is the same box that was installed by talktalk.
Re: Openreach installation
@Lb2456778 it depends on what network TAlkTalk used as they dont only use Openreach lines unlike Sky. Openreach have no record of you having one of their fibre lines and a working ONT if there is a mistake the engineer will sort it.
Avatar for Lb2456778
Thank you that makes sense.  I will wait to see what engineer says.
This message was authored by: elwl
Hi. I'm in a similar situation to this. What was the outcome in your case? Thanks
@elwl Use your address and check what you have if it shows up!
BT Broadband
