Discussion topic: Sky mini box issue
Message posted on 22 Mar 2025 08:05 PM
Sky mini box issue
I have had 3 extenders from you to extend the range through the house. My mini sky box isn't working it keeps losing signal. The thing is we have the main hub, in the next room an extender and then the further room an extender which also has the mini hub in so it should surely work but doesn't. What do I do?
Message posted on 23 Mar 2025 07:18 AM
Re: Sky mini box issue
@Neville9 if you have the Sky Max hub and extenders these cannot link to the Sky Q Mini which has te get its WiFi fed from the main Q box if you call Sky they should either send you a booster just for the Q signalor arrange for an engineer to call.
Message posted on 24 Mar 2025 12:04 PM
Thanks, yes after psoting this message I called Sky and the lady was very helpful, turns out i had an old box that we coudl utilise to get it up and running! Thanks again!!
