9
This discussion topic has been answered Discussion topic: Sky max pod won’t connect
This message was authored by: Fc47
Slow speed issue was fixed yesterday but now my sky max pod will not connect my hub so no longer have WiFi in all rooms
Avatar for Fc47
This message was authored by: Fc47 Answer
Re: Sky max pod won’t connect
Thank you, managed to reconnect the pod through the my sky app and adding the device with its serial number
@Fc47 What was required to do your original fix?
Avatar for Fc47
Openreach came and fixed external fault.  Have had to reconnect some devices to the hub but it's like no longer finds the pod
@Fc47 Did you per chance do a reset on the sky Hub?
Avatar for Fc47
Possibly the open reach engineer did yes
@Fc47 Call sky then and have someone walk you through the steps!
Avatar for Fc47
This message was authored by: Se25
How did you do this?
@Se25 there are several different reasons why a pod may not connect as explained here https://www.sky.com/help/articles/sky-wifi-booster-max-pod.
If you are still stuck talk to Sky who can see your hub and system remotely and can usually talk you through how to sort it.
This message was authored by: Smudge4
I have this problem. I have 2 Sky pods to boost my WiFi. Both have disconnected and I can't get them to reconnect using the app. How do I get in contact with the right dept at Sky to talk me through how to fix it?
