Discussion topic: Sky max hub
This message was authored by: Fee56
Sky max hub
Why wont my sky max hub connect to my sky q box using wps?
This message was authored by: FLC
Re: Sky max hub
Because it isn't compatible with the Q mesh.
Avatar for Fee56
Re: Sky max hub
What do I do please? All help greatly appreciated!
Re: Sky max hub
@FLC @Fee56
The Max Hub doesn't have the proprietary AirTies technology which went into the Q Mesh, but WPS doesn't need that: it's a global standard and should work just fine as long as the Hub and the main Q box are in range of each other and both WPS  buttons have been pressed briefly (because a long press on the Max Hub WPS button acts as a router reset)
