Discussion topic: Xelion phone system not able to make calls
Message posted on 06 Jan 2025 02:12 PM
Hi,
I mostly work from home and use a telephone system called Xelion to make outbound calls. As of today, this no longer seems to work, and I am only met with a series of 3 beeps on repeat when dialling a number.
My IT has advised it is an issue with the new Sky router, as some colleagues who are with Sky have the same problem. I am a new customer to Sky after moving house just prior to Christmas.
Interestingly, this was not an issue for the couple of days I worked on this WiFi before Christmas, and only seems to be an issue on my laptop as I am able to use the IOS application with no issues.
I have checked the broadband shield and set this to 18+ as well as adding the Xelion website to allowed addresses but this hasn't helped.
Any advice is greatly appreciated.
Message posted on 06 Jan 2025 02:16 PM - last edited: 06 Jan 2025 02:20 PM
Re: Xelion phone system not able to make calls
@Kieranw15 If it's just a laptop affected have your tried flushing the dns?
- Type cmd in the Start menu search bar and press Enter
- Right-click Command Prompt and select Run as Administrator
- Type ipconfig /flushdns and press Enter
- A message will confirm that the DNS Resolver Cache was successfully flushed
- Type exit in the Command Prompt or select the red X to exit
Restart your laptop.
If this doesn't work you could try unplugging the hub for 1 hour to see if it picks up a new IP, as it was working before it might suggest an ip issue.
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
Message posted on 07 Jan 2025 09:59 AM
Hi,
Thank you for this but unfortunately that doesn't seem to work.
The information I have received from IT seems to indicate this issue is on Skys end and related to the new routers.
Message posted on 14 Feb 2025 07:49 PM
Did you get any contact with Sky as I have the same problem?
