Discussion topic: Sky max hub and wireless printer connecting
Message posted on 26 Jun 2024 02:52 PM
Hi,
just got dky max hub, trying to connect it to my hp 5530 hp wireless printer, recognises hub but wont connect,....help!!!
been 2+. Hours and still no joy!!!!
Message posted on 26 Jun 2024 02:56 PM
Re: Sky max hub and wireless printer connecting
@Mickeys+mum try lowering the wifi security setting from wpa3T to wpa2 in the My Sky app. If that doesn't work temporarily turn off the 5GHz WiFi band and connect the printer once connected turn the 5GHz band back on.
Message posted on 21 Jul 2024 02:25 PM
Hi Chrisee,
thank you so much that worked, been pulling my hair out for days trying to get the printer to work, it nearly went in the bin, many thanks again 👍
Message posted on 27 Sep 2024 04:08 PM
You really are a genius - I too was very close to throwing the printer in the bin. The SKY guy on the phone said it was a problem with the printer. THANK YOU
Message posted on 27 Nov 2024 09:46 AM
Many thanks, Chrisee, fixed and saved me loads of time 🙂
Message posted on 17 Dec 2024 05:44 PM
Hi Micky+mum
Please can you let me know which one of the workarounds Chrissie gave you used to connect your printer to the WiFi? I've got my Sky Max on order and want to be forearmed should any printer issue arise ...I use my printer everyday for business so it is vital I'm not without it thank you rgds Simon
Message posted on 17 Dec 2024 05:47 PM
I changed the security setting and that worked - hope you get yours sorted too
Message posted on 01 Mar 2025 02:50 PM
Brilliant! 72 year old dip read the post and did what it said🤦🏼 ......... it works. Thank you sooooo much.
Message posted on 15 Jan 2026 11:18 PM
I tried this - no luck but now can't find how to switch the 5ghz back on - help???
Message posted on 16 Jan 2026 07:41 AM
I can't remember but I probably googled ' change security settings on hp printer ' sorry can't be more help
Message posted on 16 Jan 2026 09:36 AM
@Vicki1231 if you havectge white Sky hub the eetting is in the advanced settings fir the Hub under WiFi labelledslightly confusingly "diasbale wifi" go past the various warnings and just click thecslider for 5GHz back on.
If you havectge white Sky a. Black hub its a bit more complicated.
