Discussion topic: New hub
This message was authored by: IAN.R.WOOD
New hub
Fitted new hub aĺl ok  but mini box will not connect to sky Q although it's ticked all the boxes on screen
Re: New hub
@IAN.R.WOOD what router do you have from Sky ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for IAN.R.WOOD
Re: New hub
Sky hub 4.2
Re: New hub
@IAN.R.WOOD wrote:
Sky hub 4.2
@IAN.R.WOOD are you connecting your mini box with the WPS button and pressing the corresponding button on the nearest piece of Sky Q equipment. If thats the router the WPS button is on the thin right hand edge
Re: New hub
I'll try that tomorrow
