Discussion topic: Sky hub with wifi 7 mesh
This message was authored by: Markyh_uk
I'm switching to sky broadband from virgin , I currently have my wifi 7 mesh system (3x BE9300) with using the virgin router in modem mode , I also have a dedicated axe 75 router for quest 3 vr only .
I realise you can put the sky router in modem mode and therefor would have to put my mesh system in AP mode and disable wifi on the sky router .
on my current system I have a separate IOT , MLO for various types of devices .
can I mimic this set up with the sky router . Is there any problems that could arise .
Re: Sky hub with wifi 7 mesh
@Markyh_uk
Sky Hubs don't have a 'modem mode': they always act as routers.
@Markyh_uk assuming you are buying a full fibre service from Sky it should be possible to connect your Netgear unit directly to the ONT if you want. You will lose the landline facility but is should connect either by using DHCPv6 PD which 80% of Openreach lines supportor if you are unlucky you can use the DHCPv4 Option21 method I think your router supports.
if you want to use the Sky hub you have a choice of either connecting the Netgear in access point mode in ehich case I would disable the Sky hubs wifi. The alternate is leaving the Netgear in router mode and use it in a double NAT configuration which most apps are happy to use.
Avatar for Markyh_uk
Hi ,
thanks for your reply .
My WiFi 7 mesh is a deco tp link be9300 .
i don't want to use a double Nat , I've had issues before , especially with gaming .
so I guess I'll have to use my mesh in AP mode and disable sky router wifi .
i guess what I'm asking is can you see if there's potential issues  with this configuration.  I don't want to lesser the effect of my mesh system .
I don't need the phone line .
when the city fibre engineer comes this Friday , is this something he can make work .
Yes , it's 1gig fibre
Apologies it should of said can't not can in my original post . I realise the sky router can't be put in modem mode
@Markyh_uk Connect the Main Tp-Link direct on the new CF City Fibre ONT lan connection, and NOT use the sky Hub at all!
CF CityFibre Engineer is there to get the Fibre network connected, all the rest is going to be down to you, let him put the sky Hub on get connected and ensure it is all working with at least one device connected to the sky Hub, once you are happy switch it all over....
The ONT is just like the VM Hub in modem mode operation!
Sky will only support the sky Hub so if you need anything it needs to go back on the connection.
@Markyh_uk try the Deco connected directly to the ONT using DHCPv6 PD which most lines support. If that doesnt work then use the AP mode
@Chrisee Thought the CF CityFibre was no matter what able to support?
@JimM1 you are correct but I can't see the poster says it is a CF connection.
@Chrisee Here "" when the city fibre engineer comes this Friday , is this something he can make work . ""
Excellent. Thanks for the help . Bypassing the sky router completely sounds like the way forward .
@Markyh_uk You should only need to connect your mainTp_Link wan connection to the ONT. Few tweaks may be required to get all you need operating as you require!
So my max hub  arrived and the engineer installed the line . He didn't know much about what we've been talking about on here so as soon as he left I unplugged the sky hub and plugged the Ethernet cable from the ont to my deco mesh hub . It worked perfectly first time . 1100 gb download speed and similer upload speed , it's been fine ever since .   The only thing that was different was with the sky hub connected it had 3 green lights , but with my deco connected it had top two green and bottom amber .
however today my girlfriend was cleaning and unplugged the deco hubs , there were off for an hour or so , now I can't connect back to the ONT , the deco hubs just go red . The lights on the Ont are still two green bottom amber .
I've tried turning off Ont and deco for 5 mins . Still goes red on deco and won't connect .
