Discussion topic: Sky fibre
This message was authored by: Emmamitchinson
Sky fibre
I recently changed my package, and moved onto sky gigafast, yet im capped at fibre500.. it was yesterday it was changed, reset sky max hub, by plug, on/off.. when will I receive gigafast to my hub?? Many thanks.. Emma
This message was authored by: Me134
Re: Sky fibre
How are you testing the speed, what device and is it hardwired to the router? You won't be getting the maximum 900Mbps via WiFi.
Not a Sky employee
Sky Q with 2GB UHD box using WiFi
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
2 Windows desktop PC's hardwired to each Deco, everything else using WiFi
