Discussion topic: WiFi keeps dropping out
Message posted on 06 Apr 2026 12:52 PM
On at least 5 occasions recently, we have experienced breaks in our WiFi connection
Message posted on 06 Apr 2026 12:54 PM
Re: WiFi keeps dropping out
Wi-Fi or broadband? They are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
