Discussion topic: wifi keeps dropping out
This message was authored by: Dencar777
Re: wifi keeps dropping out
@Dencar777
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
