Discussion topic: Sky fibre ethernet problem
This message was authored by: bigmurs
I got sky fibre installed today and the internet stayed on for about 2 hours.The ethernet light on the ont was off, so rebooted everything and it stayed on for about 20 mins then went off again and this cycle has continued Has anyone experienced this?
Re: Sky fibre ethernet problem
@bigmurs
If you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
Avatar for bigmurs
Thanks for the reply,
I have tried all the steps as shown on city fibre site and also on my sky app
When you switch off ont,wait a couple of minutes, then switch it back on it all works for about 20 mins or so , then ethernet light on the ont goes off and sky max hub red light comes on and all broadband is lost
Im going to get a new cable to try that, but dont know if thats a waste of time?
@bigmurs it is worth trying swapping the cable but In suspect either the ONT is bad or there is an issue with the hub both of which will require Sky's assistance.
