Discussion topic: Sky engineer visit
This message was authored by Si99 This message was authored by: Si99
Sky engineer visit
Hi all
does a sky engineer have to visit my home?
I thought open reach would activate at the box end of my road and then I plug my router in?
my order has a sky engineer booked for my home?
thsnks in advance for assistance
Re: Sky engineer visit
@Si99
Are you moving to sky from another openreach provider, is this a new connection or are you upgrading your speed?
@Si99 a standard activation of a Superfast service is normally done remotely assuming you have a working Openreach line. However upgrades to Ultrafast or where Openreach want to switch the service from copper to full fibre always require an engineer's visit. The engineer maybe one of Sky's trained broadband engineers or from Openreach or one of their sub-contractors it varies.
Si99
Thank you for the replies
i am moving to sky after 2 years on virgin, prior to virgin I had Vodafone in 2020 which was via the phone line with speeds up to 70mb
cheers
@Si99 Virgin Media engineers often "helpfully" remove the Openreach line while installing their line which is maybe why you need an engineer.
Si99
The virgin engineer didn't come into my house this time as virgin was installed prior to my move to Vodafone and bsck to virgin....would the virgin engineer remove the open reach line from the exchange?
cheers
@Si99
If your area has been activated for Ultrafast fibre then any new orders placed would result in you getting your service over FTTP rather than FTTC which would require an engineer to attend and run a new fibre cable into your home
I am NOT a Sky Employee
@Si99
Putting the address into the BT Wholesale Availability Checker should indicate which provisioning type is applicable.
Si99
It says I do not have permission to post pics
Si99
@Si99
If you could post the first couple of lines of text below the table, that would help.
Si99
Thanks for your help
@Si99
That suggests an FTTC area so the activation should be remote unless Openreach think you dont have a master socket in your home
Si99
Cheers, I have a master socket as used Vodafone okay previously.
