16
Discussion topic: Sky conversion kit
This message was authored by barcasm1 This message was authored by: barcasm1
Re: Sky conversion kit
Hi
The cable is a bit short for me to place the router where I want it, what spec is the cable so that I can get a slightly longer one?
@barcasm1  You can buy longer ones from any good electrical shop to the length you need, just take the other one with you to check it has the same amount of wires in it as the one you are looking to get.
