Discussion topic: Sky broadband
Message posted on 16 Nov 2024 07:51 AM
Sky broadband
The middle green light on my wifi router keeps flashing orange every so often and then goes back to green again. I've checked the signal on the app which says everything is fine. Why does the orange light keep coming and going.
Message posted on 16 Nov 2024 08:20 AM
Re: Sky broadband
@Symonemcevoy the internet light on Sky hubs is green when the hub is connectedcand amercwhen it has lost connection. The hubs will try to reconnect. What is likely to be happening is there is a burst of electrical noise on the line which causes the connection to drop which stops and tge connection is re-established.
If you post your hub's connection stats forum members should be able to see more but only take those stats when the light is green see Find your Sky Broadband router statistics
