Discussion topic: Sky broadband setup
Message posted on 31 Aug 2024 09:21 AM
Sky broadband setup
Message posted on 31 Aug 2024 09:33 AM
Re: Sky broadband setup
@LiamB05 Are you having Fibre to the premises installed this is where the engineer comes in and the no engineer part is the setup of the router.
Message posted on 31 Aug 2024 09:37 AM
@LiamB05 wrote:
The current tenants of the property have sky broadband already setup
As @Highlinder indicates, a new order may well be the trigger for an FTTP installation.
If it's in the UK, putting the address into the BT Wholesale Availability Checker should indicate which broadband provisioning type is applicable.
Message posted on 31 Aug 2024 10:13 AM
Message posted on 31 Aug 2024 10:23 AM - last edited: 31 Aug 2024 10:25 AM
So the address will be getting an FTTP connection delivered from a pole, hence the requirement for an installer visit.
