Discussion topic: Broadband down
This message was authored by: Rjc1977
Broadband down
My broadband is down. The checker insists the connection to my hub is up every time I try, I even tried it with the job powered off and it still insisted the connection to the hub was up! Re-seating the cables didn't help and nor did resetting the hub.
Re: Broadband down
@Rjc1977  If you wait around an hour as that is the normal timescale that the server checks if you are still connected to keep the connection going to do another check with the service checker, but this time can you press on broadband to see then if it finds the fault.
Avatar for Rjc1977
Re: Broadband down
Thanks. The checker has finally actually admitted it's down. Bit annoying that it makes it look like it's running a test and gives the wrong info if it's actually just giving out incorrect cached data.
Re: Broadband down
@Rjc1977  What options did it give you now seeing it is down?
Avatar for Rjc1977
Re: Broadband down
It gives the option to to run a test then eventually says "We're having some problems and our tests are unavailable at the moment."
Re: Broadband down
I have escalated your post to Sky who may be in touch with you regarding this via a private message on this forum or an email to you, both of which will invite you to a private chat. This will now be tomorrow morning.
More information about this process can be found in the link below.
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147/
This message was authored by: Tom-W19
Re: Broadband down
Thanks for escalating. We've sent an invite to @Rjc1977.
Tom
