Discussion topic: Sky broadband not working
This message was authored by: Amanda220
I have checked connections and it is saying it working but there are no lights on the sky router. Have. Checked it's plugged in and switched on but still not working
Re: Sky broadband not working
@Amanda220
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
