Discussion topic: Sky broadband issues
Message posted on 09 Nov 2025 07:07 AM
Our broadband connection was meant to go live on the 5th November. We had already experienced no internet and tv for 5 days waiting on this date after cancelling with bt. I'm starting to rely regret charging broadband providers as it's now almost 10 days without internet and they still haven't connected it or told us what the actual issue is. To be the delay makes absolutely no sense whatsoever since by also uses open reach and we did not have an issue with the internet or connecting when issuing bt so how can there be this big issue now? What should we do! Not sure I can take having to spend anymore money on data. It's costing a bloody fortune!
Message posted on 09 Nov 2025 08:02 AM
Re: Sky broadband issues
@Caroline9118 sorry but unfortunately because you cancelled with BT yourself you are stuck. What should of happened is using the One Touch Switch system your new provider Sky would manage the whole switch including the cancellation so that where there are delays which can happen the old service stays connected. Ofcom introduced this system to avoid the issue you now have but it requires that Sky handle all of the steps if the customer cancels directly with the old supplier it cannot work.
Message posted on 09 Nov 2025 08:25 AM
So how do they fix it?
Message posted on 09 Nov 2025 09:28 AM - last edited: 09 Nov 2025 09:35 AM
Just to clarify, did you place an order with Sky without talking to BT, or did you personally cancel the BT service either before or after contacting Sky?
Cancellation and subsequent new provisioning always has an unpleasant interval without service, which is why customers aren't supposed to do it that way: it's why the 'one-touch-switch' system exists. Were you not advised about this when you started the process?
Message posted on 10 Nov 2025 11:41 AM
Unfortunately the person on the phone from sky never mentioned any of this to me. I told her my bt services would be cancelled as of the 31st oct and they never questioned this and told me the earlier they could book me in for was the 5th.
Message posted on 10 Nov 2025 01:18 PM
@Caroline9118 The OTS takes care off a lot but it is not a 100% does it all, still a few problems, when the other ISP get's cancelled there is just no work around and sky may just not flag that up, also until they get conformation back from OR when the change over can take place it is a lottery before then.
