Discussion topic: Sky broadband is highly disappointing
Message posted on 20 Jan 2024 08:37 PM
We have had sky broadband for a while now. However in the last year, the speed on speed checked says exactly the same every day etc. however we struggle to have decent WiFi on any device connected.
we have tried every options to reset the WiFi and move the box etc as the website says and still the same issue.
We can't even upgrade to a better broadband speed. Now sky are putting prices up. Why can't we get better internet when other suppliers can offer speed and fibre broadband at a lot higher speeds at lower prices.
Message posted on 20 Jan 2024 10:05 PM
Re: Sky broadband is highly disappointing
@helpwouldbenice Please can you post your router stats so the forum can advise on any issues. This link explains how to do that https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717#
Message posted on 20 Jan 2024 10:29 PM
A lot of the time are our smart tv functions do not work.
our phones are connected with fully strength signal but can not load any web page or messages. Or extremely slow.
System Up Time: 906:07:16
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 100530282 258157465 0 239820 3543376 906:05:28 LAN Down 0 0 0 0 0 00:00:00 WLAN (2.4 GHz) Up 34942158 16802441 0 5746 1528 906:04:50 WLAN (5 GHz) Up 267442365 104016881 0 4011184 0 906:04:46
Message posted on 20 Jan 2024 10:56 PM
The 34999 inbound speed would typically indicate an FTTC connection being automatically capped by Openreach DLM because of adverse line conditions being detected.
Message posted on 21 Jan 2024 07:31 AM
@helpwouldbenice your connection at 35Mb/s is not great and could be higher so its worth running the connection test in the My Sky app to see if it will book an engineer to check the line if it diesnt it is worth calling Sky and asking for that to be done.
However that is probably not the reason why your smart TV is not working. All of your devices use wifi to connect which can often becfar slower than the connection spedd to the hub. There are things you can do yourself like making sure the Hub is out in the open above things that block the signal like radiators etc. Wifi speeds are affected by the type of construction of your home - solid walls and foil faced insulation are a nightmare - the amount of interference from your neighbours and simple distance. Many people find a single free Sky hub is insufficent to provide decent wifi through out their home so buy third party kit.
The one type of issue that might be helped by a faster connection to the hub is where you have multiple members of the family online at once.
