26 Oct 2022 10:47 PM
Hi, as the title says my sky broadband has been dropping constantly over the past two days, when I run a check I'm told there are no issues sometimes then at other times it says there is an issue with my Wi-Fi or broadband and then it comes back on a bit later.
I have carried out a full reset and turned off and on and the problem persists.
I will add the stats from the Sky Q router
Many thanks
27 Oct 2022 08:17 AM
Posted by a Superuser, not a Sky employee. Find out more@dhoadleyCan see there is issues in the connection dropping. If the broadband test is not picking anything up then you will have to contact Sky to run more in depth tests.
