Discussion topic: Sky WiFi max not performing well .
Message posted on 04 Jul 2024 09:01 AM
Wifi max isn't performing well, only had it two weeks . Won't connect to my tv or ps5 the signal isn't strong enough . It disconnects from devises upstairs , the old fibre box is better but I'm paying 5 pound more for this one
Message posted on 04 Jul 2024 11:12 AM
Re: Sky WiFi max not performing well .
If you have Sky WiFi Max (the service not just the new white hub), then after 2 weeks you can go through the extra support process to get help and any required boosters: https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
Message posted on 05 Jul 2024 08:52 AM
@stereohaven How is it that the older router performs better ? I pay more for less? Thanks for the guide tho
Message posted on 05 Jul 2024 09:36 AM
@Wazzerwareham Obviously no one wants you to pay more for less, so go through the process to see if the issues can be resolved, that is what you are paying for after all.
As it says on the page, you can even leave the contract if there is a real problem that cannot be resolved satisfactorily.
Why is the old router better in your scenario? Dunno. So many variables it's impossible to say for sure on an internet forum.
Plenty of people have complained about issues with the Sky Max Hub on here, while others have had a smooth journey.
Not having a strong enough signal where you want it could mean faulty hardware (the hub itself), a software issue, something affecting the signal in your home, all sorts.
The good thing about paying extra is they need to fix it for you or let you go, so make them earn their extra money because there are a number of positives in the long term for having a more up to date Wifi 6 router (assuming it works...). 😁
