6
This discussion topic has been answered Discussion topic: Sky WiFi Max - question
This message was authored by: DavidKent
I am about to renew my Sky Broadband subscription and interested in the Sky Wifi max router.
My current router has four ports on the back and I need to keep this number as I have several things I plug into my current router (e.g., CCTV)
How many ports does the Sky Wifi max router have please?
David
Re: Sky WiFi Max - question
@DavidKent
@DavidKent
@DavidKent
Note that FTTP broadband would use ethernet port #4 for connection to the ONT (marked WAN for Wide Area Network), so leaving only three available for other things.
@DavidKent
I would note that you can always buy an ethernet switch for about £10 which will give you another 5 ports (4 usable after using one for linking it to your main hub)
I am NOT a Sky Employee
Avatar for DavidKent
Many thanks.
I don't understand the "Sky Glass 55" (on ethernet) & two Stream Pucks (one ethernet / one WiFi)
BT Halo 3+ Ultrafast FTTP (500Mbs), BT Smart Hub 2"
What does this all mean?
Some forum users have signature files listing their household hardware.  This can help give context to replies: for example I have Sky Glass and Stream, but don't use Sky Broadband (which isn't available here)
This message was authored by: CoffeeDrinker
@DavidKent wrote:
Many thanks.
That is @TimmyBGood signature, listing the hardware & services he(?) uses. It isn't part of his answer to your question 🙂
Lounge: Sky Glass gen 2 65” volcanic grey, Denon X3500H AVR. M&K K Series 5.1.2 speakers, PS5 Pro, Apple TV 4K, Sony X800 M2 4K player.
Bedroom: Sky Glass gen 1 43” dusky pink, Apple TV 4K.
