89
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky WiFi Max Hub (white): No WiFi but wired connection is ok
Locked
This message was authored by: fgmclark
Devices won’t connect
Router appears to be working perfectly however - doesn't appear on any devices to be able to connect to it
This message was authored by: Greenfingers001
Re: Sky Max Hub not connecting to anything
Hi there @Ellie2206 , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
This message was authored by: Dipti13
Re: Dipti Patel
Tried everything but no luck
This message was authored by: Taranath
Re: WiFi Down
Just press WPS button on your router for 30 seconds and then your wifi router will reboot itself and the connection will be restored automatically and wifi will start working.
Thank you
This message was authored by: SimonOS
No WiFi signal coming from the hub
Our devices can not pick up a WiFi signal from the sky hub
we currently have no internet service into the house
the hub has power and is showing a white light on the front
This message was authored by: Marrian14
WiFi down
My WiFi is down but everything is connected and all checks have been completed and are okay. Can you advise what is happening please?
Re: No WiFi signal coming from the hub
@SimonOS  Have you tried to do a factory re-set on the hub to see if this brings it back?
This message was authored by: Kath30
Re: No WiFi but wired connection is ok
I have done the factory reset by holding down the wps button. The WiFi then came up on my phone but said it has an issue and has gone back to not being found again
This message was authored by: Rob1897
Connected our services ok last night. This morning - no connection for broadband or tv
Connected our new SKY Broadband and tv services last night (SKY Max hub) and all ok. This morning, nothing works - no SKY WiFi to connect for devices and no signal for tv.
This message was authored by: Neoublie1984
Re: Sky WiFi Max Hub (white): No WiFi but wired connection is ok
Woke up thismorning to find my phone cant rind my hub. Ive aeen that others are having the same issue. Could someone tell me when this will ve resolved?
This message was authored by: Pazy
Re: WiFi not visible
This has worked a treat
cheers for all your help peeps.
stay safe
pazy
Re: Connected our services ok last night. This morning - no connection for broadband or tv
@Rob1897  Have you tried to factory reset the hub?
This message was authored by: Tbrady1
Re: WiFi Down
this worked for me, thanks
This message was authored by: Delibelli
Same problem here. We had the issues with the Sky Puck which affected lots of people too but fixed that. Now we're having to restart the router in the morning but the puck still says there's no WiFi connection. So frustrating, we're new customers and are not impressed so far.
I tried what was said about doing a reset by holding in the WPS. Button untill it blinks and it seems to have worked. 👍
Locked
Answered - Go to Answer
