Discussion topic: Sky WiFi Max Hub (white): No WiFi but wired connection is ok
Message posted on 24 Sep 2024 09:16 AM
Re: WiFi Down
Exact same issue for me as well. All devices showing as 4G and can't find network.
have rebooted and reset modem and same issue.
have run an Ethernet cable to laptop for work and it's picked up and working but can't connect anything wirelessly
Re: Dipti Patel
@Dipti13 there is a fsult where the white hubs are not transmitting their SSID to devices so they can connect despite the hub showing a white connected light. if that is your issue the fix for the white hub is to do a factory reset. Press and hold in the wps button on the right edge of the hub for up to 30 seconds releasing it when the led on the front starts flashing rapidly green. Once restarted the hub should be back to normal.
Message posted on 24 Sep 2024 09:17 AM
Re: WiFi Down
We've got the exact same issue aswell
Message posted on 24 Sep 2024 09:18 AM
Re: No WiFi
@DJL94 thete is a fsult where the white hubs are not transmitting their SSID to devices so they can connect despite the hub showing a white connected light. if thst is your issue the fix for the white hub is to do a factory reset. Press and hold in the wps button on the right edge of the hub for up to 30 seconds releasing it when the led on the front starts flashing rapidly green. Once restarted the hub should be back to normal.
Re: WiFi Down
Same issue here not finding the devices but the checker says no issue
Message posted on 24 Sep 2024 09:24 AM
Re: Wi-Fi not showing as an available network
Hi there, wondering if you got this sorted? Having same issues this morning. Thanks.
Message posted on 24 Sep 2024 09:25 AM
Re: WiFi Down
Message posted on 24 Sep 2024 09:26 AM
Re: Dipti Patel
Sorry, still not working
Message posted on 24 Sep 2024 09:28 AM
Network not showing
Woke up to no WIFI this morning. Run the diagnostics on the app and it says everything is looking fine other than the hub not having WIFI (there doesn't seem to be an option to help with this?) Everything was working fine last night but this morning the network isn't even showing as available to join. Can someone please escalate this if possible as I'm meant to be working from home right now. Many thanks.
Message posted on 24 Sep 2024 09:29 AM
Hi therecis a common fault wherecthe white Sky Max hubs have stopped transmitting the SSID. The workround is to factory reset the hub by pressing and holding in the WPS button on the right hand side for up to 30 seconds unitil the led on the front starts flashing green rapidly then release tge button. Once the hub restarts things should be back to normal.
Re: Wi-fi connection
Hi there @Chris347 , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Message posted on 24 Sep 2024 09:31 AM
Re: Network not showing
@Crg_Oz see this post
Message posted on 24 Sep 2024 09:33 AM
Wifi not working
Message posted on 24 Sep 2024 09:36 AM
Re: Gigafast has been installed today and isn’t connecting
Hi @Sharon973
Your post has been escalated to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Just look out for the chat bubble to start the conversation.
Here's more information on how Community Messaging works - https://community.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Tom
WiFi is no discoverable
Router is showing white light but WiFi is no discoverable by any device in the house.
I did broadband check from website it shows everything is okay .
Any solutions to this are much appreciated.
