Discussion topic: Sky SR203 Router wont connect if I use a previously used SSID
Message posted on 31 Jan 2026 10:55 PM
I had to reset the router after upgadijng to 500mb from 100mb and I want to reset the 2.4Ghz and 5Ghz SSID's to the same SSID names as perviously set. When I go this my devices wont connect however I change the SSID to something other than I had used before then my devices do connect. HOW do I make the SR203 forget previoly used SSID names?
Message posted on 31 Jan 2026 11:07 PM
Re: Sky SR203 Router wont connect if I use a previously used SSID
@Paul+Onyett Not sure what you are trying to do, just change the names on the setting screen for the SR203 hub, save and apply the settings as needed! Best to do it with an Ethernet connected device easier than wireless wifi!
