Discussion topic: My ring doorbell doesn’t work
This message was authored by: AngelineC
Since I transferred from Virgin to sky my ring doorbell will not connect to the Internet or keeps dropping out.
Re: My ring doorbell doesn’t work
@AngelineC Suspect that you have a poor wifi signal to the ring doorbell, have a look on the doorbell app, device health then signal strength will display RSSI-?? the two numbers in the high 60's then poor signal!
Running RSSI-46 on mine, but do have a dedicated AP at the doorbell location taking care off the wireless wifi signal at that area!
Understanding wifi recommendations for Ring devices
