Discussion topic: Sky Router cannot hold a wifi connection
This message was authored by: SteveWestrip
My Sky Router has started not being able to keep a wifi connection. It started with my Windows 11 laptop and now it is happening with my iPad. The behvaiour you see is a connetion being made, it works for about 5-10 seconds and then it drops and tries again. This cycle happens repeatedly and the behaviour is the same on both devices. I have power cycled the device more than once and although this fixes the problem for about 30mins it comes back again. Ethernet connections work fine. In the past 24 hours it has dropped my internet connection about 10 times, typically for about 5 mins at a time. Pretty sure the router is on the way out.
Sky's help AI couldn't understand this issue and I have failed to get hold of a human being (frustrating enough that it is making me consider other options for broadband)
This message was authored by: Addie15
Re: Sky Router cannot hold a wifi connection
