Discussion topic: Sky Q router needs rebooting every few days
This message was authored by Dogmandfds This message was authored by: Dogmandfds
Sky Q router needs rebooting every few days.
I've noticed the issue that has been getting progressively worse over the last year.
Reboots used to be weekly generally, now required every other day.
Symptons:
- internet access slow, page timeouts.
- high latency between clients (connected to both LAN and WLAN) when pinging gateway address 192.168.0.1
- ping responses generally >1000ms, or no packect response
- download speed on speedtest down to 1 mbps
Resolution:
- reboot router.
- issue returns after 48-72 hours generally.
Sky Q router is 7 years old
Router stats 2 hours after reboot.
My initial thoughts are potentially a hardware/firmware issue with the router given it's age.
Can anyone offer any advice on this please?
Re: Sky Q router needs rebooting every few days
Hi @Dogmandfds
The first point of call would be to report the issue to Sky and get a replacement router sent out. If that doesnt fix the issue then you'd have to start looking at what devices are connected to the router.
I am NOT a Sky Employee
Dogmandfds
Just requested a new router, should arrive tomorrow hopefully
This message was authored by Argyller This message was authored by: Argyller
Did this solve problem?  I have exact same issue with router requiring rebooted every day.  Router is only 2-3 years old.
Dogmandfds
The replacement router has definitley been better. For the first 6 months I have only had to reboot the router - say once/twice a month.
I have definitley noted that recently that has increased slightly - probably two/three times a month now after having the router for 8 months or so.
I have had an issue with downstream speed on my line which has not helped in assessing performance, but that has been resolved now.
My overall experience is that the router hardware will likely need to be replaced every few years as performance and reliabilty reduces over time. Same with my Sky Q box to be fair - I'm on box number 3 now
