Discussion topic: Issue with router requiring rebooted every day
This message was authored by Argyller This message was authored by: Argyller
Hi,  use sky broadband with sky Q  and 3x mini boxes.  For last few months, every single day (during day) Sky Q looses signal to sky router (over Wi-Fi) and internet becomes unavailable throughout house.  Wi-Fi still present and strong, but not connected to internet.  Router shows 4green lights.  Need to reboot router (nothing else) and entire system restores itself to normal.  Getting really frustrating having to reboot every day.  Any thoughts?  On very good 44MB BB service.
Re: Issue with router requiring rebooted every day
@Argyller sounds like the wifi signal from the hub to the nearest Sky Q bix is marginal so while the Q box mesh stays working and the Q minis work anything requiring an external connection stops working.
You need to improve that backhaul,connection. Assuming the hub cannot be moved closer -just raising the hub higher can help in many cases - then running an ethernet cable from the hub to any of the Q boxes should sort the issue. If that is impractical consider buying a powerline adapter kit which uses the mains wiring to carry the signal.
