Discussion topic: Sky Max
This message was authored by: Sqaull
Message posted on 07 Jan 2024 11:00 AM
Sky Max
I seem to be having constant dropouts on my broadband when I try to download anything on the Xbox. This then bins off all connected devices to the Sky WiFi Max Router. The only solution is to reset the the router, in order to get the connection again.
Find out more
Message posted on 07 Jan 2024 11:08 AM
Re: Sky Max
@Sqaull check the xbox's network set up to ensure it is either set to get its config from the Sky hub or if set up with a fixed IP address thst you have reserved that address on the router.
