2
This discussion topic has been answered Discussion topic: Xbox ethernet connectivity
This message was authored by: Jordan10
Hello,
I have been trying to connect my xbox to the Internet via WiFi but failing miserably so have now connected an ethernet cable up from my router. NAT type its Open when it connects. The xbox connects for a minute tops and then drops the connection, I have reset the xbox, power cycled the xbox,  reset the router and opened recommended ports on the router settings. If I disconnect the ethernet out the back of xbox and put it back in it again connects for a minute. Any help appreciated
Avatar for Jordan10
This message was authored by: Jordan10 Answer
Re: Xbox ethernet connectivity
Thank you, I have fixed it I had a booster plugged in that run externally to the property so my xbox was confused and trying to connect to that rather than the router itself.
Thank you for the response
@Jordan10 check the cable ethernet cables can break if they have been bent too tightly.
Avatar for Jordan10
