Discussion topic: Sky Max hub dropping connection
This message was authored by: reading12
I've just upgraded to sky max hub full fibre gigafast thinking it would improve signal strenght but it hasnt. The internet constantly cuts out and struggles with connection. Paying more for a worse signal at this point! It is extremely frustrating after first 24hrs after setting up. I have a sky extender pod on order. Is this normal or have I got a faulty sky max hub? Cheers
Re: Sky Max hub dropping connection
@reading12 check the light on the hub and use this trouble shooter see https://www.sky.com/help/articles/hub-lights-explained-start
While as with any electronic device you msybhaveca faulty unit it is more likely some other cause. Also check the ONT if thatvis showing a red light tat would indicate an issue with the fibre connection
