Discussion topic: No hub connector
This message was authored by: michael+oc
No hub connector
I've been sent a sky max hub with no connector
Re: No hub connector
@michael+oc if it is a replacement for another Sky hub the same cableccan be used. However do check the packaging as the cables are normally under the cardboard the hub was sitting on.
