14
This discussion topic has been answered Discussion topic: Sky Full Fibre advertised for my property but Openreach unable to deliver, what next?
This message was authored by: mannp
I signed up for Full Fibre in October 2025 and Openreach text to say install would be 10 November, 2025.
Between signing up and the 10th November I have 5 text messages from Openreach, 'will I be in' etc, I answered Yes.
The day before the install Openreach texted to say the install would be the end of Jan 2026, some 4 months after signup with Sky.
I have called Sky multiple times and nothing has happened.
I now have to pay exorbitant fees from my current provider, due to Openreach failures and Skys lack of action.
Can anyone help me get some info here please?
Is this really 'One touch transfer' from Ofcom, what a joke.
Re: Sky Full Fibre advertised for my property but Openreach unable to deliver, what next?
@mannp this isnt a matter thst market regulation could help it is down to a legal issue with having to get a third party agreement for the cable to your property pass over their property. The broadband market is highly regulated by Ofcom but in the real world these type of issues do occasionally delay installs you have been unlucky there is nothing Sky or you can do to speed things up.
This would of happened which ever ISP you chose but you are likely to receive compensation for the delay in commissioning the service see Customer Auto-Compensation | Sky Help | Sky.com
Hi @mannp
The one touch transfer system is for when you are switching between two providers who are part of the scheme and you are switching on the same technology. To me it sounds like you are switching from either traditional broadband or Fibre to the cab, to full fibre. This would not fall under the one touch switch and can come with delays if Openreach find difficulties in getting the new fibre cable ran to your property.
To get an insight into what might be the holdup on your install, you can go to this site, use the address checker & then post the resulting table & text below the table back here.
I am NOT a Sky Employee
Avatar for mannp
Thanks for your response @jamesn123
Details below;
Avatar for mannp
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Handback
Threshold(Mbps) WBC FTTC Availability WBC SOGEA Availability
High Low High Low
VDSL Range A (Clean) help 80 72.2 64.8 Unavailable Available
VDSL Range B (Impacted) help 80 67.1 Unavailable Available
G.fast Range A (Clean) help -- -- -- -- -- Unavailable --
G.fast Range B (Impacted) help -- -- -- -- -- Unavailable --
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install Process
WBC FTTP Up to 1000 Up to 220 -- Available 1 Stage
Other Offerings Availability Date
VDSL Multicast Available
Exchange Product Restrictions Status
FTTP Priority Exchange N
WLR Withdrawal Y
SOADSL Restriction N
Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential OH Potential Wayleave issues.
FTTP is available and a new ONT may be ordered.
The exchange is not in a current fibre priority programme
As a WLR withdrawal exchange, product restrictions apply
SOADSL is not restricted at the exchange
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
For all SOADSL services,the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
Avatar for mannp
Doesn't this mean Full Fibre is available?
@mannp Was this part also in your advise from sky along with all the other blurb etc?
Delivery of service
Occasionally there are factors outside the control of Sky that may lead to delay. In rare cases where complex provisioning is required, or where issues occur, installation could take up to 90 days. In this event the latest your services would be a
Hi @mannp
The important part of that text you pasted here is: "Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential OH Potential Wayleave issues."
This suggests that your fibre line will come from a pole overhead and onto your property, however Openreach are suggesting that either the pole, or the cable, or both, may be on property that requires a wayleave. Wayleaves can often take time to be granted as it requires the property owner to approve & sign the access.
@mannp
As @jamesn123 indicates, if Openreach is waiting for neighbouring landowner consent to either fly a cable across or burrow underneath then unfortunately that could take an entirely unpredictable amount of time, and even your January date might well slip..
Avatar for mannp
Thanks all for the reponeses; been out of the country, so a little delayed replying.
I haven't received any 'blurb' from Sky, in fact I haven't received anything at all, apart from a welcome email.
After a couple of calls I made to them, they have not replied, gave no status updates and ignored my requests for help.
Not sure if thats allowed in the blurb, but its a pretty unprofessional way of doing business.
I'd understood the fibre would be pulled in the same route as the copper, which is underground for me, so wasn't clear on why it now needs to come over a pole.
Thanks again for the insights.
@mannp Sometimes the information is just not as it seems, but you posted back and that info supplied shows Pole fed, with a wayleave issue, it's all in the hands of OR to get the fibre to your home and doubtful if sky even have any update to give you. It's the way that you need to call them and don't expect any call back's is the way to treat it all!
Avatar for mannp
Looking at the ratings for all the broadband suppliers the expectation of quality of customer service is very low, so I guess Sky is no differant.
I am left in discussions with my current provider to reduce their over inflated out of market charges now, while waiting for a transfer.
Its a pity we don't have a market watchdog, driving improvements in the industry, oh wait we do, but they are too busy going after Apple.
Avatar for mannp
Thanks.
I was more referring to the finger in the air pricing my existing provider is coming up with between now and install date, as this doesn't feel very regulated.
Noted, useful link on the compensation, thanks.
@Chrisee wrote:
@mannp
Unless it's one of the altnets which takes a relaxed view about asking neighbours whether they mind having a pole in their driveway...
Avatar for mannp
As others mentioned it might be, its delayed again.
With no communication from Sky except a text, 'your new date in now ...' thanks Sky, nicely done.
