4
This discussion topic has been answered Discussion topic: Sky Fibre Cable Damaged
This message was authored by: gerald_reeves
The 'sharp metal' clips fitted by the engineer to hold the fibre cable to the wall, have cut through the outer plastic covering and the cable looks damaged and 'about to fail'.   How do I book an engineer  to check this/fit a new fibre cable?   Thank you.
This message was authored by: Highlinder Answer
Re: Sky Fibre Cable Damaged
@gerald_reeves  If you answer no after the SMS it should put your through to an advisor.
@gerald_reeves  The quickest way would be to give Sky a call and report this to book an engineer to come out to repair this for you. Just dial 150 on your landline and ignore it trying to send you texts back here and hold on the line till you speak to an advisor.
Avatar for gerald_reeves
Thank you for that   -   will try the 150 call   (and hopefully hold-the-call, and avoid 'fob-off' with SMS text messages).  Cheers.
.....  and  eventually got thru' to a 'real' Sky person, and engineer book.   Thanks.
